Recommendations for Electric Bilge pump
Nov 23, 2011
87
Hunter H31 Kent Island Yacht Club
Hi All,
I have 1984 Hunter 31 - The Rule 500 gph died this weekend.
Looking for recommendations on a new pump -
What are you using?
Reviews at West Marine are all over the board for Rule and Johnson products.
So let me know your thoughts.
Thanks
Mark
Dream Too
Apr 30, 2013
36
Hunter 35 Michigan
I just replaced my Rule 750 Auto pump with a Johnson 1000, with an Ultima sensor. So far so good, the sensor seems to work as it's supposed to, and while doing a clean out of the bilge this weekend, that pump seemed to being working as fast as the hose I was using to rinse things down. As far as longevity, that will have to be seen.
Nov 26, 2012
1,654
C&C 40-2 Berkeley
Capt. Wayne Canning
Go to You Tube and search Understanding Bilge Pumps by Capt Wayne Canning. It's everything you need to know about bilge pumps.
May 24, 2004
7,176
CC 30 South Florida
Just go ahead and replace with another Rule 500 gpm. You can go to a larger pump but you may have to increase the size of the discharge hose to get the benefits. I have held the belief for many years now that bilge pumps are more of a convenience item than a safety item. They are large enough to discharge the incidental water that collects in the bilge but not adequate to deal with any significant water intrusion. A 500 gpm should do a good job of discharging the bilge on your h31.
Oct 27, 2011
154
Hunter 1980 Hunter 30 San Diego, Mission Bay
Like the OP, I wonder about the reliability of Rule pumps and if there is something "better" available. I replaced a defective Rule pump with a new Rule and within a year the new one failed. And my boat is pretty dry - I think the pump cycles maybe no more than once a week. So I would have expected the pump toi last longer than this. Is there a better pump out there?
Nov 23, 2011
87
Thanks all
I replace it with the 750 gal/ h since it had the same outlet.
MN
Apr 19, 2011
456
Hunter 31 Seattle
I put a 2000 GPH pump in replacing the 500. Its still using the same hose and shoots out the side of the boat pretty good!
Anyone know of a "better" float switch that runs slightly longer than the ones that just float?
Nov 26, 2012
2,315
Catalina 250 Bodega Bay CA
Since the smallest diameter in hose line system will dictate max gallons per hour expelled, most people buy too large a pump. Chief
