Recessed Lights (in my case on a 2002 H306)
38
Hunter 306 Deale, MD
Hello!
I recently acquired a 2002 306 and would like to swap out the cabin lights for LEDs. Apparently, the recessed lighting has been discontinued, but the incandescent replacement can be obtained here:
http://shop.hunterowners.com/hp/part.php?m=306&c=5&p=52267
My question is, has anyone replaced these with LEDs? Is there a fixture that will fit the existing mounts or that are easily adaptable? Alternatively, is it possible to just swap out the little incandescent bulbs for LEDs?
Thanks for any help!
Nico
Nov 6, 2006
10,104
Here are some other G-4 replacements. I use these in warm white for main cabin light. Very good light and bright.
http://www.ledwholesalers.com/store/index.php?act=viewProd&productId=400
Just check to be sure they'll fit in the housings and will be oriented correctly. I had to turn the base on one of my fixtures to get the LED's to face correctly.
EDIT: Make sure you know your pin orientation.. These come in "back pin" or "side pin" .. usually if the bulb is pointed out of the fixture, you'll need a back pin.. If the bulb is laid horizontally in the fixture, you'll need a side pin unit. I used to show about 4.5 ampere draw with three lights on in the cabin.. now with LED's it is right at one ampere.
69
Hunter 306 Chester Basin, Nova Scotia
Replaced all the lighting in my 2005 Hunter 306 with LED bulbs. All bought from China, cost was less then $30 shipped to my door. Ceiling list side pin G4 bulbs. Been running with them all season, no issues.
Jun 28, 2005
440
Hunter H33 2004 Mumford Cove,CT & Block Island
Hello!
Nico
Here are ones I used
http://m.miniinthebox.com/g4-5050-s...10lm-light-bulb-ac-dc-12v-2-2-5w_p311442.html
I tried various ones, cool white, warm white, various lumens, etc., you have to bend the leads a little but they fit in the fixture. I tried some others from Defender but their diameter was too large.
Aug 20, 2013
38
Thank you all!
This is fantastic info! I ordered a couple of G4 LEDs and will try them on the boat this weekend. If they work as expected I'll buy the rest.
Thank you again for all your feedback!
Nico
May 18, 2010
543
Oday 27 Gulfport, MS
Take care in your selection of LED bulbs.
http://store.marinebeam.com/whyounetokna.html
+1 for using a properly controlled setup. Shorts etc due to over powering is not something I want to be wrong on. Other threads here warn if potential electrical short fires while your charging system increases power output. I'm no expert with electricity, but follow Hello Below's link for a proper description.
I did buy lights from Marinebeam and am happy with their selection and customer service.
Thanks HB!
Nov 24, 2013
1
Beneteau 323 Annapolis MD
I have also replaced all halogens with LED G4 replacement bulbs. I have bought the soft white ones because I don't like the cool white. Of course this is a personal taste. Colour wise they don't seem that good because the colour of some are yellow-white (as expected) but some others have a bluish color! But who cares, there were so cheap....Consumption wise, they are EXCELLENT. How long they will last? I don't know yet. I just bought them a couple of months ago.
May 28, 2009
764
Hunter 376 Pensacola, FL
The plastic on my main cabin recessed lights was yellowing and some of the bezels were cracking and splitting. I replaced them all with these:
http://www.westmarine.com/webapp/wcs/stores/servlet/ProductDisplay?productId=950128&catalogId=10001&langId=-1&storeId=11151&storeNum=50523&subdeptNum=50573&classNum=50578
They work great, I think they're very affordable, and they fit in the exising holes. I just needed to drill some new mounting holes for the provided screws, because they don't lne up with the old screw holes.
