Nice looking refurbished trailer. I'll check those links, too, as I begin my own trailer rebuild.
On the trailer neck, was that the original extension or did you have to add that yourself? Not sure I have room for on of those on my trailer.
Any thoughts on disc brakes or just saving $$ on drum rebuilds?
The trailer hitch extension came with the trailer. As for disc or drum brakes, here's the advice I followed from the Champion Trailer website:
Disc brakes require higher static line pressures for effective braking torque to be experienced. Therefore a lighter towed load, such as the 18’ boat in the example above, will probably not experience effective braking with disc brakes, due to the lower mass & therefore lower differential pressure created at a given rate of deceleration, whereas a heavier towed load such as the 22’ boat noted above will have a much better braking response with disc brakes, because of the higher towed weight, & greater differential pressure creating a higher hydraulic output pressure.
Most trailer drum brake systems have uni-servo wheel cylinders [ single push rod ] . In a uni-servo brake system, as hydraulic pressure is increased in the wheel cylinder, the push rod is extended & pushes against the primary shoe, moving the primary & secondary shoe in an arc. The end of the secondary shoe is anchored against an anchor pin at the top of the brake cluster [ backing plate]. This results in the primary & secondary shoes of the brake cluster having LEVERED force applied to the brake shoes.
Because of this levered force, developed at the drum brake cluster, drum brakes will give better braking torque, at a lower hydraulic pressure & are therefore more effective for lighter towed loads.
In addition to this, the surface area of the pads on a drum brake system is normally larger than that of a comparable disc brake system. With a comparable coefficient of friction for the drum & disc brake components, the greater surface area of the drum system will give greater frictional resistance due to the larger surface area of the pads.
With all of these factors taken into consideration it is advisable to install drum brakes on trailers if the GVW is less than 3000#.
