G
Greasiehands
I would like to know what steps by step instructions is use to rebuild my cluch.The organial tail shaft was cut, and I got the moter as is.I found a tail shaft but it is about 3/4 inch longer then before.Also I'm changing the final drive from a "V"-drive to a Parogon drive.The only problem is putting the cluch together.Can I just push the tail shaft into the cluch? or is there more to that, that I don't know?Thanks for any help that you provide.Ralph
