Jesse: What's the issue with butyl tape on the 310?
I don't know how this happened but I don't have any photos of the chainplates.
I will try to remember to fix this when I get home tonight.
But to try and explain it without a photo, the chainplate for the upper shroud and intermediate shroud is a piece of stainless steel that goes through a slit in the deck and bolts to the bulkhead. The slit is about an 1/8 inch or less larger all around than the chainplate. There is then a cover that goes over this chain plate from the top of the deck that screws into the hull. The cover is supposed to hold the bedding material in place.
Here are my problems with using this setup the way it is. First, the cover screwing down. I don't like the idea of trying to use butyl tape on something that is just screwed down. Especially on wholes that have already had the screws taken out and put back in the same spot. To me this is asking for the resistance of the butyl tape to cause the hole to strip out. Or you are not tightening the cover down enough and you need to compress butyl tape for it to really work.
Second, the slit for the chainplate is squared. This wouldn't allow for a nice packing of of butyl tape but instead just push out the butyl tape. If you look at Maine Sail's write up on Compass Marine he talks about the importance of counter sinking the holes. I think there is enough area to make a counter sink area by putting chamfer edge on the slit but that would involve completely removing the chain plate so you don't accidentally damage the chainplate while doing this.
Lastly, the chainplate cover also has a larger than necessary slit. This would allow the butyl tape to either get really dirty or ooze out on hot days or from movement inside of the cover. While this one isn't really a deal breaker for me, it's something that could be done better and avoid some issues.
Eventually I will make some changes to allow this to be bedded with butyl correctly. But that will involve removing the chainplate, converting the cover to through-bolted instead of wood screws. This will likely involve making a new cover that is a tighter fit. Ideally I would like to find a way to have the covers welded onto the chainplates.
For now I will continue to use polysulfide. With the mast up there is enough space to get in there with some dental picks and get all the old caulk up. Primer the area and then recaulk with polysulfide. This has to be redone every five years to avoid leaks. So at some point it will bother me enough to make the conversion.
Fair winds,
Jesse
