G
ghadrill
I am planning to rebed stanchions with no direct access below deck due to a glued head liner. 2) What do I do if I run into the situation where the deck bolts are screwed into a tapped plate epoxied in place in the deck? Someone mentioned on my model this is likely. ie no bolts with nuts -simply a tapped plate. (Hunter 340) 3) Preferences re bedding compound based on the approach to the task? Thanks all.
