Calling on experience ports rebedders!!!
Just started on our spring project of rebedding our C30 leaky ports. Got the kit from Catalina direct, found as much information about doing this, as usual on this forum.
Here's the catch, when I took apart the ports, I could see a gap (1/8") in between both hull section (inside and outside), I have not found any indication anywhere, about the action to take regarding the gap between the inner deck skin and outer deck. Must it be sealed prior to installing ports, if so, with 3m 4200 or expoy? must it be left alone and risk water infiltration between decks? does it seal itself once the ports frames are tighten?
Your input would be appreciated, as I really do not wish to have to redo the job again, getting so close to having a dry bilge, although it seems very elusive!!!
Thanks to all,
Ghislain
"Emilie-Jolie"
C30TRBS 4708.
Thanks to all,
Ghislain
"Emilie-Jolie"
C30TRBS 4708.
