I have a leak on my 1998 Hunter 310 and believe it comes from a stanchion. I pulled the stanchion off, cleaned it up, and readied it for butyl tape. I used the instructions I found online and watched a sailrite video and did exactly as shown. Unfortunately, on my boat, the backing plate is not accessible, and so when I tried to screw in the stanchion (down about an inch) the butyl tape got all screwed up. I noted on the instructions that it is recommended to tighten by NOT using the screw heads, but on the other side. I cannot do that. So, is there a way to get the butyl tape to work (or did I waste $40+). If not, what is the preferred material to re-bed the stanchions.
Additionally, the screws seem REALLY hard to turn as I get close to the end.
I appreciate any help in advance.
