Rear Winches on H340
Bob Martin
Has anyone installed rear winches or had them installed on the H340. I'm looking at a couple of Lewmar 40's. How did you installation go and how did you run the sheets? I'm looking at running them inside the arch with a couple of fairleads attached to the base of the arch. Any thoughts or suggestions are appreciated.
Jim Russell
Rear Winch
Perhaps you saw my response before, but in case you have not: I have factory installed rear winches. However, I use them almost exclusively for the spinnaker. Occassionally I will use them for the jib sheets when reefing, or the main if I need to use a winch to pull it in. In such cases, I run the sheet around the base of the winch (using it as a block) on the cabin roof and back to the rear winch. However I do this only as a temporarily.
Darcy Peck
Rear Winches on Hunter 340
Like Jim I also have the factory installed self tailing winches. I lead the jib sheets aft from the genoa blocks through a bulls eye fairlead I mounted on the outboard side of the arch to a block fastened to the stern pulpit then fwd to the winch. Works great for me & my crew. No longer have to struggle with those unpopular sheet stoppers and was able to utilize the original sheets.
