Winch Cleaning
I've used both mineral spirits and diesel with good results. I prefer mineral spirits, however, only because every time I've used diesel, it seems to get on the gel coat, me, and everything else and it smells bad. Mineral spirits seem easier to clean up afterward. My preferred grease is white lithium. Comes in a tub, has the right viscosity, and lasts forever. I, too, use an old toothbrush to apply it. FWIW, I used to have Barient winches on my last boat -- and they are out of business. Sure enough, I needed to replace some worn out pawls and springs when I stripped one of the winches and wondered where to get them. Much to my delight, I found that some old Lewmar winch kits that I had in the tool box had extra pawls and springs and bingo! they fit the Barient perfectly.
