I usually jack the boat up . . .
. . .rather than lowering the front. The process you refer to requires boat stands, and I have none.I have a hydralic roll-around jack. I place some strong boards on the frame members of the trailer to act as a platform for the jack. I use a 1 foot square board as a lifting pad to make contact with the hull. If you try to lift directly with the small pad of the jack, it will just punch a hole in the hull (that's bad).There are only certain areas where you can safely lift/support the boat. These are areas where the interior structure of the boat joins the hull (i.e. bulkheads). On the port side (left), it is near the front of the cockpit where the cabin starts. On the starboard side (right) it is about 1/3 the way along the cabin (from the back). This location ends up being about 3 feet more forward than the port side.You will notice in the interior of the boat in both these locations than an interior structure member joins with the hull. If you try to lift/support the boat in "non-supported" areas of the hull, it will bend and damage the hull.The bow is a much stronger and can be lifted either just in front of the keel trunk or more towards the front roller on the trailer.When I jack up a side of the boat, I place some short 2 x 6 boards on the bunks and lower it back down on those boards. So, the bunks are still carrying the load, not the jack. I think I needed 3 (2 x 6) boards in the back to get sufficient clearance to remove the keel.The key things are that everything should be "over-engineered" when lifting, and the jack should only do the initial lifting, blocks, etc. should do the supporting.You can accomplish the same thing if you have boat stands rather than a jack. My only concern about lowering the front of the trailer, supporting the stern with stands, and then raising the front of the trailer, is that the process may tend to topple the stands in the back.Be safe !!!I hope this helps,TedP.S. I also use this lifting process for painting the hull under the areas of the bunks.
