Keel bolts
Don't believe you will get anyone to commit to a figure on keel bolts.The primary reason is that "stainless"steel in the absence[sp] of oxygen,such as a nut on a bolt and in a moist enviorement develops corrosion or gaulling[sp] which would make a tourque spec not valid. I would do as Ed suggested and for peace of mind check tightness as often as you feel comfortable with.There would have been a torque value on new clean bolts but that would not apply to your situation.
