Re-Stringing Reefing Line in Boom
23
Catalina 270 Colorado
I have a 2002, Catalina 270. The reefing line came out of the sail and into the boom. When I tried to retrieve it I got just and end that was already attached to the boom. I tried to snake the line back through with no luck. I see in the drawing in the manual that there is a tie of two lines inside the boom. Any ideas how to re-string this back up? Right now all I have is the rear reef line running through the boom and back into the block on deck. Nothing for the luff of the sail near the mast. Thanks. :confused:
May 23, 2007
1,306
Catalina Capri 22 Albany, Oregon
Prior owner removed the reefing lines from our Capri 22 boom. I had to take the ends off to re-run them. Found out the hard way there was a pin holding the aft sheaves in. Oops!
