A Cautionary note
I have a 79 H33 with a 2gm (15 hp) auxiliary engine, and a 2 bladed bronze prop that is not original with the boat. At full throttle, the engine will do very near the governed 3600 rpm underway, 6.5 knots or under most any condition that I would be using an engine. The Yanmar is manufactured to rev, being rated for continuous duty at I believe 3300 rpm. At 3300, the boat makes well above 6 knots. It doesn't respond like a motorsailer docking, backing, accelerating or decelerating. It doesn't sail like one either. There is going to be a sailing penalty with a fixed 3 blade prop. Anybody changing props needs to also make certain that the engine will still make its designed operating rpm range, or else be exposed to accelerated mixing elbow coking problems that are pretty well documented in the archives here.
