David Fox
Any suggestions on "pressing" the engine end flange back onto the drive shaft. I pulled the shaft as part of replacing the cutless bearing and am not sure how to "press" the flange back on. Also is there a recommended lubricant or "anti-sieze' compound that shuold be used for the flange and propeller before replacing on the brass drive shaft? Thanks in advance for the helpDave
