more like 6 to 8K depending on whether it's
a steel or lead keel on you boat ! Not to steal your thunder Steve, but in the Spring of 2000 I was looking at a Hunter 34 that had a 5'6 draft. The price was attractive enough but the draft was a deterrent. So I contacted Mars Metal and got a quote of $5,000 + freight to go to Plattsburgh, NY, (about 400 miles from where Mars Metal is). But the keel on the Hunter 34 is steel, which meant I had to get it cut and drilled for the bolts by a professional welder, which added to the cost. So I forgot the idea and kept looking for a 34 with a shoal draft. Eventually I found one and bought it. My thinking is like Ed's,: if you must have shoal draft, then consider selling yours and getting another boat. I believe the article Steve is referring to was in a Cruising Magazine about 7 or 8 years ago. I do remember it was about a Pacific Sailcraft 37 and the owner had dealt with Mars Metal and was very satisfied with the job and the results. Good luck
