Re: Head Maintenance
Mike Linstrom
The manual head on my '85 H34 is a Groco Model HF but I have no way of knowing if it is original equipment. It looks as though it's a replacement or someone moved it over a little as there are abandoned drill holes in the fiberglass beneath it and just to the side of its present mounting position. It has a Y valve and seems to work OK but there is friction in the plunger. Do you know where I can get some manufacturer's literature/diagrams on this model?
V
Vic Willman
Groco Head
Contact GROCO at: info@groco.net website: www.groco.net GROCO 7240 Standard Drive Hanover, MD 21076 410-712-4242
Peggie Hall/Headmistress
Rebuild it and lubricate it
After you get the exploded drawing that shows how to open up the pump, buy a rebuild kit and a tube of SuperLube. After you've replaced all the parts in the rebuild kit, slather it LIBERALLY with SuperLube. It should work smoothly all season.
Dec 2, 1999
15,184
Don't think it was original.
Mike: I do not think that this was the original head. Our '85 H'31 came with a CW head. We replaced it with a Groco after about 2 years because the manifold base(connects bowl to pump) cracked. The price for the replacment part was nearly as expensive as the new Groco. I have had three heads in my boat over the years, CW, Groco and Jabsco. The hole pattern on each one of them was different. I have had to drill at least one new hole for each head.
