Jay
Regarding the question of docking bow or stern first, I had an interesting experience with trying to come in stern first. Maybe someone has comments and/or advice. We have a new 306, so docking a boat of this size is still a fairly new to me, and we're in a new slip to boot. A couple of weeks ago, we went out in what turned out to be 20 knots of wind, gusting to around 24. And we were getting most of it right at the dock because of the wind direction. Departing went ok, barely, but we ended up just motoring because the wind was greater than my confidence. On the way back in, I thought "ok, I'll give stern-first a try, and then abort if it doesn't work". Luckily, we're in a outside slip, so there's a huge amount of room to maneuver. So I come in with the slip 90 degrees to port, and turn 90 degrees to stbd before putting it in reverse. The plan was to leave plenty of room to get up to speed in reverse and straighten out before getting anywhere near the dock. But even after getting up to speed in reverse, the helm/rudder angle seems to have absolutely nothing to do with where the boat wants to go. I think this was due to the 20 knots of wind blowing the bow around. The wind was probably just about on our beam at the time I was having problems. Anyway, we had a much easier time once I gave up and came in bow-first. Do you all try to stern-first in winds this strong? I have no problems doing stern-first in normal winds.Another question: departing the slip in strong winds on your beam. Say I'm in bow-first (so I have to back out), and we have 20 knots on the beam. As soon as we release the bow line going in reverse, the bow gets blown off and tries to remove our anchor against the outboard piling as we pass it. Very embarrassing. What's the fix for this? Here's a picture of our slip: a short finger pier on one side, the main dock in front, and 2 pilings set maybe 45 feet out from the main dock. So we have bow lines to 2 cleats on the main dock, and stern lines to the 2 pilings. (0r the other way around if we're in stern-first.) One other thing: there are "helper-lines" running from the outboard pilings in to the main dock. The main idea I have had since the last incident is to first use a boat hook to hold the boat to windward, and then release the bow line. But as soon as the boat starts to move backwards, the person (not me!) up on the bow has to be very deft to let go with the hook, maybe rehook a bit later on, all while not getting pulled overboard. And if it's my wife, it's really not clear that she can hold the boat from being pushed sideways by 20 knots of wind (say). (I will not usually have an experienced crew!)Thanks for any thoughts you have on this!
