Hello fellow Vegans. I recently removed the water pump to replace the
seals and the impeller. After reinstalling it, I found that the pump
direction seems to be reversed. It now seems to pump out towards the
intake hose. When the motor runs it makes lots of bubbles in the bucket
of water instead of drawing water. Turning the pump 180 degrees would
correct the problem, I presume. But if I turn the pump 180 degrees, the
hoses don't line up. Could I have installed the impeller the wrong way?
Cheers, Trevor V2915[Non-text portions of this message have been removed]
