I do remember reading about column collapse.
I believe boats with fractional rig are more prone to it.
What happens is that when you have the mainsail up, the whole luff edge is pulling on the mast to aft. The fractional forestay is pulling on the mast to forward.
So when you totally remove the mainsail force, the only remaining force is the forestay pulling on the midsection of the mast and the backstay pulling from the top of the mast....
Then you get a buckle at the midsection when you get a gust or you go over a big wave and the boat lurches.
There may be other ways for column collapse. I am definitely not an expert sailor.
rb
rb
