The Combi system is greased through two ordinary "Zirk" grease fittings: One
is on the port side of the Combi gear box, just beneath where the cable
attaches from the operating handle. It is not easily seen without using a mirror.
The other is on the prop hub itself. The bronze plug must be removed and the
grease fitting inserted; then replaced with the plug when finished.
Ed Davis, Vesper, V1868[Non-text portions of this message have been removed]
