I have a Catalina 309 with a factory installed autopilot.
My problem is that the lever that engages my Raytheon autopilot with the steering wheel won't stay in place.
It doesn't help to adjust the autopilot belt tension by loosening the allen head screw and clicking the square adjuster knob one click at a time either tighter or looser).
When I turn the adjuster knob tighter, so the lever engages the belt onto the wheel well, and the lever stays in place, but the autopilot motor drags (it remains still slightly engaged) even when the lever is disengaged. This is no good
When I turn the adjuster knob looser, so that the lever engages the belt onto the wheel well and the steering wheel turns freely when the autopilot lever is disengaged. Then the lever pops loose in the first minute that the autopilot steering. This is also no good
A bit of background: I had this problem ever since I purchased the vessel in 2009. A year ago replaced the belt with a genuine Raytheon spare part (the old belt had frayed cords coming off one edge that had tangled in the mechanism). Every thing behind the belt cover looks in good order.
I work around the problem now by slipping a loop of twine over the lever to hold it in the up position.
Any ideas? Anybody have a similar problem with the autopilot lever popping out ?
