I have recently purchased a 2005 Catalina 310 and would like to know if anyone can tell me where the Raymarine through-hull transducer and paddle wheel might be located. It is not under the front 'V' berth as with later models. Thanks, Sandy
On Concerto, our 2002 C310, there is a floor panel just inside the forward berth bulkhead. If the '05 is the same, lift that and there they should be.
Also, FYI, the "compass" for my Raytheon auto helm is located in the main bilge, aft of the pump under the bilge access panel in the main cabin sole.
Just in case you don't find it there - the "compass" for my Raytheon auto helm (2001 Hull 52) is located in the aft cabin area, inside the sliding cabinet port site, against the bulkhead between cabin and head.
All connections from the mast head instrument are in a little black box in the forward area of the bilge (main cabin) at the first separator.
