I have recently purchased a Hunter 36 and have found that the ST60 depth unit only works when in depths greater than approximately 7-10 feet. When it is really needed it either displays --- or Last depth 7 ft.
It is currently set with with a depth offset of W/L +2.0 feet.
Questions:
1) what should be the keel offset for the Hunter 36?
2) Does the unit act as described above when the measured depth is less than the minimum depth entered into the unit?
Thanks in advance for any suggestions.
Questions:
