Raymarine ST4000 MK2 Wheel Drive - Ball Bearing Size?
Tpoo
Jun 15, 2020
7
Catalina 30 MKII Tall Rig Kemah
Does anybody know the size (diameter) of the stainless ball bearings used in the Raymarine ST4000 MK2 wheel drive? I think they are 1/4 inch but if anyone knows for sure, it would be a big help. There's 21 of them and they ride inside a plastic cage. Managed to recover most of them when the unit split apart when I touched it (the two halves don't seem to be secured together very well). But still need to replace a few missing ones.
Anyway, I've searched and searched online to find the size of these bearings and for some reason this information appears be highly confidential <sarc>. Will go buy a set of vernier calipers if I must, but just trying to take the lazy way out right now. Thank you for your help.
Tpoo
Tpoo
Jun 15, 2020
7
Thank you, Tally Ho. Therein lies the problem...but I've heard from someone else that they're 8 mm, or 5/16 inches (more or less equivalent),
Jan 7, 2011
5,758
Oday 322 East Chicago, IN
Good luck!
must have been an “oh sh@t“ moment when those bearings bounced all around the cockpit:huh:
my older design St4000 doesn’t have ballbearings…
but be careful if you open up the gear box attached to the motor…lots (like 60) little gears in there…don’t ask he how I know :facepalm:..
Greg
Beneteau 323 Annapolis MD
Get a gauge for measuring drill bitS. Put the ball in the hole that lets it go/no-go. SAVE IT FOR THE NEXT TIME.
Jul 18, 2014
16
Hunter 34 Sydney
I must be missing something. Why not measure one of the balls you saved? A cheap micrometer would be best but you can eyeball a tape measure for reasonable accuracy. You're not looking for 1/1,000th accuracy here.
Take the ball to a tool store. Measure with the most expensive tool they have. WRITE IT DOWN ! Put the tool back on the shelf. Go get a beer with the savings.
Jul 31, 2023
1
Beneteau 35S5 Chicago
Tpoo
What did you conclude? Are they 8mm 316L stainless steel balls? Where did you source the balls if you did? Thanks!
Likes: JavaMan
