Raymarine st1000 configuration
Mar 21, 2015
28
Hi. I took the plunge and opted for a Raymarine autopilot after good feedback from the forum. My dad fitted it (I uploaded some photos) and I found that the autopilot kept falling off. It's pretty obvious why, I was hoping that the wise folk on here could recommend the best work around for my tiller set up?
Sep 13, 2002
203
easy ... strong elastic band/shockcord or a cable tie (the reusable type).Enough to hold the autopilot on to the pin on the tiller, but not so much that you can't quickly detach it.I would have fitted the pin on the tiller about half an inch higher - I suspect that the autopilot will bottom on the locker cover and bounce off the tiller pin.
Sep 13, 2002
203
I also suggest putting the pin on the side of the tiller that faces the autopiliot ( starboard side) rather than on the top (I assume it's an L shape like a cup hook) - that way the weight will be perpendicular.
Nov 8, 2001
1,818
Also tighten the bolt at the aft of the tiller
clamp
Sent: Saturday, December 19, 2015 9:15 PM
To: AlbinVega@yahoogroups.com
Subject: [AlbinVega] Re: Raymarine st1000
configuration
type).
tiller pin.
This email has been checked for viruses by Avast antivirus software.
www.avast.com
May 30, 2006
1,075
Buy a few of the plastic end pieces as they can snap off. When it does, your unit is useless and u will hand steer the rest of the trip.(Part that the pin goes into)"dade_jeremy@... [AlbinVega]" AlbinVega@yahoogroups.com wrote:
Mar 21, 2015
28
Thank you for the great feedback. Apart from the hiccup with the fitting its very easy to use. Will send photos when re-fitted it. The tiller was the one fitted when we bought her. There is another tiller which my dad tried but he did not like. Maybe that is the original tiller :) Thanks again.
