I acquired a used SL 72 plus and am having trouble getting it to work. According to the previous owner it was never fulling installed on their boat. I have replaced the r126 flat molex connector that connects to the scanner because it had loose wires and gave me the "scanner Not Responding". Once i replaced the molex connector, that problem was solved. Continuity check on the cable confirms it is good. Shield on the cable is very rusty. Not sure if that is an issue. The scanner rotates. The display works. I ran the hidden diagnostic and all functions passed.
However when I transmit the screen shows no returns. I found a tip on the web about adjusting the gain manually. My screen stays clear till I get to 92+ then it starts to go black. According to that check, the cable has an issue. I have checked it multiple times with the same result. Before I buy a new cable, I am hoping someone can help..
Thanks,
S/V Island Fever
Thanks,
S/V Island Fever
