Raymarine S2G (ST6001) pilot with Simrad linear drive?
jviss
Feb 5, 2004
7,090
Tartan 3800 20 Westport, MA
Does anyone have any knowledge or experience using a Simrad electric/hydraulic linear drive with a Raymarine pilot? I have an ST6001+ control head and the S2G pilot (formerly 150G), and plan on using the Simrad HLD350 Mk. II linear drive. Any insight or experiences are welcome!
Thanks,
jv
jviss
Feb 5, 2004
7,090
Follow up
In case anyone is interested:
I have a Raymarine S2G w/ ST6001+ head. I bought both a used Raymarine Type 1 linear drive, and a Simrad HLD350 Mk. II.
The T1 is an electrically driven recirculating ball-nut lead screw; the HLD350 is a dual-acting hydraulic cylinder driven by a reversible electrically driven hydraulic pump.
Surprisingly (to me) the T1 has lower backforce when not engaged. I assumed the hydraulic unit would win here.
To engage, the T1 has an electric clutch, the HLD a normally-open solenoid bypass valve.
As far as interfacing is concerned, the S2G shouldn't know which is which: comparably sized motors, and similar loads for "clutch."
I like the HLD. It seems quite robust, inspires confidence. It seems like it is much better sealed against weather. It seems a lot stronger. The T1 is scary inside - plastic gears, a belt drive, and it's poorly sealed against water intrusion.
Incidentally, Raymarine have a hydraulic linear drive, but it is a larger unit, comparable to the Simrad HLD2000, and it is not integrated like hte HLD350, in that the clinder, pump and reservoir are separate units connected with hoses. A nice feature of the HLD350 is - no hoses! An integral body and reservoir with the motor mountted to it, and one pipe to the other end of the ram.
Both units have rod ends that take 12mm attachement points: a stud, or pin of 12mm diameter. The Simrad manual incorrectly calls 12mm equivalent to 1/2". A 1/2" stud, pin, bolt, whatever, won't fit.
