Raymarine Unit
Jack,The 8" unit is probably as large as you will want to go in that location. Even so, you may find that it is a lot of mass up high and a bit in the way. I've never been very fond of the way that Hunter designed the 356/36 pedastal bar. You have to mount up pretty high because a lower mounting vovers two of the instrument positions on the pedastal pod.We redesigned ours (it was expensive) and had a new one bent. Ours is the same up to the pedastal pod and then bends forward following the same angle as the pedastal face and then bends up again. This offsets the whole thing forward enough to allow an instrument pod to sit lower and still not cover the pedastal pod. I looked for a picture, but could not find one.The end result is a slightly lower over all height, room for the pod and keeps all the instruments a little closer together in front of the wheel.I believe that the newer bars are two piece and the break is somewhere around the pedastal. If so, you might only have to get the upper section rebuilt if you wanted to do what we did. Would be much cheaper and easier to install.
