Raymarine / Autohelm ST50 Windvane
DanG
Jun 29, 2009
14
Tartan 33R Mexico
Has anyone replaced the bearings in a ST50 autohelm masthead wind transducer? Mine are beyond a shot of WD40 and I either need to replace the bearings or get a replacement masthead wind unit. Any advice on replacing the bearings or locating a replacement are appreciated!
derfus
Oct 26, 2009
72
Oday Oday 28, Mac-25 Presque Isle Marina, Erie, PA
Hi, Give DMI Marine a call. They rebuild all the older Datamarine stuff.
derfus
Oct 26, 2009
72
Ops, Pushed the button too soon. DMI Marine at:
DMI Marine, Inc.
18 Commerce Park Road
Pocasset, Ma 02559
main phone number: 508-564-7491
fax number: 508-564-7497
email: dmi@dmimarine.com
Dec 2, 2003
1,637
Hunter 376 Warsash, England --
Raytheon Masthead Unit - ST50
The Anemometer Bearings are as below and I would guess the wind vane uses the same bearing set:-
The bearing code is DD 830 ZZ which means OD 8mm, ID 3mm, width 4mm and ZZ means non-contacting shield. Two bearings required from NMB in Japan.
Dec 2, 2003
1,637
Remember you need the non-contacting shield version of the ball race because even the slightest drag will stop the instrument dead.
Of course you need a shield on each side of the bearing to keep dust and spiders at bay.
Nov 26, 2008
1,970
Endeavour 42 Cruisin
Is wd40 the right choice?
wd stands for water displacement. it was never designed to be a lubricant, only a sealant against moisture penetration.
Anyone know if there is there a specific lube recommended for the bearings?
DanG
Jun 29, 2009
14
Tartan 33R Mexico
Thanks for all the replies and good ideas.
Does anyone have suggestions on getting the bearings out? I have tried pushing and tapping on the shaft to drive it out the back of the housing but it does not want to move. I am somewhat hesitant to hit it too hard as I do not want to damage the shaft or the plastic housing.
Jun 4, 2004
255
Hunter 376 Annapolis MD
I had a similar problem last year and the fix was easy.
I sprayed with sailcoat, a Teflon spray lub, after climbing the mast. I soaked it thoroughly to flush out dirt and the dry Teflon was left on the bearings. It has been spinning just fine this past year.
Allan
