I just purchased an older boat with this unit - it is missing several parts and needs a pedestal mount - does anyone out there know a good source for replacement parts ?
Jim
Jim
Does anyone remember the only remotes the Catalina 30's had? I used one once and it was just a motor with a belt on the wheel and a wired remote (wireless would be great).
Stu, That is not the one. That is so much more fancy. The unit I used had the motor and belt and a wired remote with just 4 buttons (1 degree left, 1 degree right, 10 degree left, 10 degree right). I believe it was turned on when you engaged the belt with the tension lever. Very simple and worked great. For the price of that one you are better with the Raymarine X-5 and the wireless remote as the cost is about the same.
