E
Eric Fee
Have '85 Catalina 30' with Universal M25 diesel. Having problem with overheating as the result of the raw water cooling system's failure to spit water out once underway. Have adequate raw water output while idling at the dock, and while in gear initially. After about 30 mins., the raw water output gradually decreases and then ceases. One time the raw water output resumed spontaneously with a decrease in the rpms. After running twice with no problems, another time it gradually ceased and did not resume until the mechanic checked the boat three days later. At that time it operated normally while in slip. Thruhull, filter & pump/impeller appear okay to mechanic. Mechanic advised replacing vacuum break/vented loop as it may have allowed air into the system. Question: Could this be the problem? Any other thoughts appreciated.
