Raw water seacocks location on 326 hunter 2002
massimo orsini
Please help...I just purchase a 2002 326 Hunter...I loooove the boat but my head does not work..The problem is that I cannot seems to get water from the raw water hose..and I cannot find the valve to eventually open the seacock..I have the drawing of the vessel and the water schematic but the valve is not where suppose to be ..Under the batteries compartment ..??? Do you know of any other possible location???Please help !!!You can also e-mail me directly at maxorsini@msn.com
A
Andy
A guess
My guess based on a 29.5 and 340 is that its under the bathroom vanity/sink. Follow the hose and its right below your nose.
Pete
use fresh water
you can always use fresh water (from the sink)Just add it with a cup it will prevent the smell from sea water that has gotten old and smells. May not be as easy but a good alternative. The raw water thru hull should be located next to the sink drain thru hull under the sink.
Nov 29, 2004
12
- - Groton, CT
Seacock for head
On my 2002 326 it's under the cabin sole. Lift off the floor panel just forward of the engine cover and reach underneath to the port side.
massimo orsini
:) Found it...
Thank you all...You gus are all great..Thank you to the Hunter Tech Support..Congrats..They answer immediately and this is copy of the mail.----------------------------Dear Mr. Orsini, There is a drop-in in the floor outside of where you go into the head, it may be located under this drop in. Thanks, Don Martin Hunter Marine Customer Service
