One impeller blade probably broke off, jammed the casing and the others followed.
Pieces of the impeller are probably all through the raw water side of the cooling system.
Deferred maintenance, or a run-dry situation. Make sure you inspect both sides of the raw water system, upstream and downstream. Those pieces can find their way to the upstream side.
