Four years ago I replaced by Sherwood Raw Water Pump with the better Oberdorfer M202-15 unit. Has been great, but I am seeing borderline temps (190º at 80% throttle, maybe normal maybe a bit high, right?) and am thinking about pulling the cover off and having a look at the impeller vanes. Any issues with doing that? Can I just put a bit of Vaseline on the sealing ring and replace cover or must I replace, for example? I do have a spare impeller kit on board, but hate to steal its sealing ring if I don’t have to. If I do have to replace the impeller, do I need to hold the shaft in place, not letting it pull forward as on the Sherwood (on those, if you remove it, you will then have to pull the entire pump!) Any other tips?
