So why does the Yanmar 4 series have the raw water impeller housed in the back/aft end of the pump? I always assumed it was on the front. Anyway, my exhaust was running dry so I checked the sea strainer first (clear) and then opened the thru hull with the strainer top off and water flooded in. So then I make a big assumption and jump to the raw water pump impeller. I don't have side access to the front 1/3 of the engine. Good front and top access and back accesse though. So I have to take the alternator off to reach the back of the pump. Then I have to work blind ( the cover if facing away from me) get the cover off, check the impeller in place with a mirror, it look OK but the boat is 20 years old so I start to take impeller out. this takes about 1/2 hour picking at it. Get it out and it is just perfect. Put a new impeller in ( this takes about 45 minutes getting the blades into the housing) and put everything back together and rebolt the alternator. That was a 2-3 hour bloddy knuckle mess. Start engine - no water. So I disconnect the hose out the back of the heat exchanger and water pumps out great. Then I just work my way down stream taking each connection apart and getting good flow until the final fitting into the exhaust elbow. OK its the elbow. I got that off at the manifold and at the muffler, I couldn't get the exhaust hose off of the elbow. Like a warrior with his sword I left the dock with my elbow and 3 feet of exhaust hose held high.Anyway, the last thing I will check if no water or an overheat problem in the future is going to be the raw water pump impeller. Well at least I know where it is, though I have never really seen it. On the elbow issue, based on what other have said I know I will not be able to break loose the elbow from the manifold flange thingy. So I was just going to drop it off at the local Yanmar parts and service place and get them to do the heavy lifting and also get a new elbow. Anyone have a better idea?Finally, I got the boat with about 1300 engine hours, I put on 400 hours and then sudden complete blockage this weekend while at the dock.
