Fresh water vs. Seawater head
Another thing to consider: toilets that flush with pressurized fresh water use a lot less power than raw water-flushing heads because they don't have to drive a raw water pump. They just activate the coil on a solenoid valve (1-3 amps.), whereas the raw water pump usually consumes in the area of 18 amps. And they are a lot quieter - most of the noise associated with macerating electric heads comes from the raw water pump, not from the macerator - as is commonly believed.Note: when mentioning fresh water flushing heads - it is referring to PRESSURIZED fresh water flushing heads where the bowl rinsing water is supplied via your onboard pressure water system. Oftentimes, when a boat is in a river or lake, the head actually flushes with fresh RAW water, requiring a pump. Some confusion exists when ordering a head for fresh water use - if using RAW water of any type (fresh, brackish or salt water) you need the head with the raw water pump. If the head will be flushed from the onboard PRESSURE system, you order the fresh water-flushing head. I hope this will clear up a bit of the confusion that exists. Basically, if the water comes from outside the boat, you need the raw water pump, either integral or remotely-mounted. If the water comes from the onboard pressure system, you need the fresh water model head with the solenoid valve, and no raw water pump.
