Steve is right...
The PO found a simple way to eliminate sea water odor and mineral buildup in the toilet plumbing. However, I'd have done it a bit differently, one of two ways:1. Tee the head intake line into the head sink drain line. Before leaving the boat, after the seacocks are closed, fill the sink with fresh water...flush the toilet. Because the seacock is closed, the toilet will pull the clean water out of the sink, rinsing sea water out of the entire system. This allows you to conserve your fresh water by flushing with sea water, but rinses it out before it can sit, stagnate and stink.2. Stuff a small (5-6 gal) UNvented bladder into any location that's convenient to both the head sink drain and the toilet. Use a small y-valve (for this application even a 3.95 plastic garden hose valve will work), connect a fill line for the bladder into the head sink drain line...connect the head intake line to the bladder. No other plumbing needed. To fill the bladder, open the valve to the bladder fill...run water down the sink. This will allow you to flush with fresh water all the time without risk of polluting your potable water supply. The advantage to it over the 5 gal. jug you have now: running water down the sink has to be a lot easier way to refill the bladder than refilling the jug.Whatever you do, NEVER connect any manual toilet--or any electric toilet designed to use sea water either--to the fresh water supply plumbing. That cannot be done without risk of contaminating the potable water supply, damage to the toilet, or both...and EVERY toilet mfr specifically warns against it in their installation instructions. It's ok to connect to drain lines, because drain lines aren't part of the supply plumbing.
