L
Larry Connolly
Over the winter lay up I installed a Groco Raw Water Strainer on the intake for the 2QM15. Prior to this, the line only had a screen on the thru hull, which was leaking. Having replaced the thru hull with a 3/4" bronze with no screen, I thought the Groco strainer would be an improvement. Unfortunately, the pump has been working intermittently this season. It will go from pumping plenty of water for some time, but fail to pump any at all, primarily after several hours of sailing, but occasionally at a slip or mooring too. My mechanic had rebuilt the pump over the winter (which worked fine last season), and after several calls, gone over it again, checking the plate for wear. He had me lower the raw water strainer on the bulkhead, it’s now at the height of the oil filter and I’ve double checked all clamps, but I’m still getting the same problem. The mechanics last advice was to avoid starting the engine under sail, which seems a bit ridiculous. At this point I have ordered a new pump, but am interested if other people have raw water strainer for there 2QM15 and its setup. Any feedback would be appreciated.Cheerslarry
