I installed a new Raritan head to replace my Jabsco and while I was at it I also installed the Water Treatment Kit that was recommended. It seems like a pretty simple thing to install. The special t-valve that connects to the bottle of concentrate even has an arrow that tells to which way to orient it in the flushing water line.
I put the bottle of concentrate above the waterline at first because that seemed to be the safest place for it. Everything seemed to work great until I noticed a couple of days after I installed it that all of the concentrate siphoned out of the bottle while the head was not being used. I then moved it down almost to the water line and it siphoned out until the water level in the bottle matched the water level outside of the hull. I then installed it below the water line and closed the intake valve. When I checked on it a short time later it had siphoned the water out of the toilet bowl which was not large enough to contain it. It made my bilge smell nice.
Since this device seems to work much like a water level the results seem pretty predictable. I am thinking about installing a valve in the line to the bottle of concentrate and leaving it closed most of the time but there must be a better way. Any ideas what's going wrong?
