Raritan PHII
19
Irwin 38 MKII Center Cockpit West Island
I have one of these heads that is in desperate need of rebuilding. How can i determine the date of manufacture for the rebuild kit?
Dec 2, 1997
8,954
- - LIttle Rock
PH and PH II identifiers
The PH II was first introduced in 1983...if yours was [FONT=Verdana, Arial, Helvetica, sans-serif]manufactured prior to 1981, it will have a chromed dry/flush valve knob on the front of the toilet pump and uses kit PHRK. (20 years is about the lifespan of a PH II, so I'd recommend replacing the pump instead rebuilding).
[/FONT][FONT=Verdana, Arial, Helvetica, sans-serif]The first version of the PH II was manufactured 1981 - June, 1992 ...it has a plastic dry/flush knob at the front of the toilet pump and a pump shaft seal held in place by a star washer-type snap ring. [/FONT]It uses kit PHIIRK. (Unless it's post-1990, I'd seriously consider a new pump instead.)
PH II toilets made after 6/92 have [FONT=Verdana, Arial, Helvetica, sans-serif]a cartridge-type pump shaft seal with a hex nut at the top of the pump housing where the piston shaft goes through. This unit uses repair kit PHRKIIC. (Rebuild it).
If this doesn't help, call Vic Willman at Raritan: 800-352-5630 x 6 to help you identify what you have.
[/FONT]
19
The PH II was first introduced in 1983...if yours was [FONT=Verdana, Arial, Helvetica, sans-serif]manufactured prior to 1981, it will have a chromed dry/flush valve knob on the front of the toilet pump and uses kit PHRK. (20 years is about the lifespan of a PH II, so I'd recommend replacing the pump instead rebuilding).[/FONT]
[FONT=Verdana, Arial, Helvetica, sans-serif]The first version of the PH II was manufactured 1981 - June, 1992 ...it has tified by a plastic dry/flush knob at the front of the toilet pump and a pump shaft seal held in place by a star washer-type snap ring. [/FONT]It uses kit PHIIRK. (Unless it's post-1990, I'd seriously consider a new pump instead.)
PH II toilets made after have [FONT=Verdana, Arial, Helvetica, sans-serif]a cartridge-type pump shaft seal with a hex nut at the top of the pump housing where the piston shaft goes through. This unit uses repair kit PHRKIIC. (Rebuild it).[/FONT]
[FONT=Verdana, Arial, Helvetica, sans-serif]If this doesn't help, call Vic Willman at Raritan: 800-352-5630 x 6 to help you identify what you have.[/FONT]
Thanks i will take a look at it tonight!
V
Vic Willman
Ph/phii
PH was manufactured from 1960 to 1981; PHII first series from 1981 (not 1983) to June, 1992; PHII second series from June 1992, present.
I think Peggie hit the wrong key on her computer...(1983)
