Curious if anyone has actually bought/installed/used the new Raritan "Fresh Head" yet. I'm about to pull the cord on replacing my 30 year old Groco HF and am contemplating the fresh water flush.
The thought of connecting my fresh water plumbing directly to the head triggers all my red flag senses but I do understand that is what it is specifically designed to do. I also see it uses the same joker and flapper valves that many other heads use:
http://www.raritaneng.com/wp-content/uploads/2015/02/L524EXPVIEW1.pdf
I haven't done the sink drain to head inlet tee that many here have done and recommend. My sink drains to a thru hull above the water line so I'd have to use the existing head inlet thru hull and an extra valve and a bunch of fittings in a tight space.
Anyone recommend the Fresh Head?
thanks,
JMc..
thanks,
JMc..
