ramshead shackle
  • Thread starter tom o'callaghan
  • Start date
tom o'callaghan
what is the ramshead schackle at the base of the boom used for. i can't find a use for it in the owners manual, or maybe i just overlooked it
Dave Condon
Boom fitting
I am not sure what you are speaking of but will assume the metal parts sticking out at the gooseneck which look like a rams head. if this is what you are speaking of, then it is a part of the reefing. If you want to know more, then email me at davecondon@mindspring.com
Likes: 2bysea
Bruce Grant
A little more info
Tom, when I bought my boat, I had not seen that type of reefing and subsequently, the rams horn was hanging down when the boom was attached, so I was unable to reef the main with it in that position. The top of the horns need to be pointed upwards such that when you try and hook the ring on the main into the horn, it is a simple dropping of the main down to the level to hook it on. Rather than trying to wrap the main below the boom in order to hook the ring. Clear as mud? If this sounds kinda like the problem/questions your are having, email me at bgrant@cng.dl.nec.com and I will be happy to discuss further. Regards. Bruce. Neon Moon
