backing the sail
Ed's got it right, you don't have to back the sail if you veer off the wind slightly, you can go right into sailing. And yes manitoba is a long way from cape cod Bill. You see, I backed the jib once when I was there, then cleated it, next thing I knew, I was in manitoba!Seriously though, backing the jib is a great way to get out of irons. Its a pretty impressive boat handling move also. Your boat is just sitting there, sails flapping away, and you either walk to the jib clew and pull it to windward or accomplish the same by pulling on the wrong (windward) jib sheet, and the bow swings out away from the wind. This is the procedure in the following pic. The wind is coming directly from the viewer (photographer). I had been beached nose to, on shore where the viewer is standing. Both sails had stayed up all afternoon, with sheets slack, while I picked up family on shore. The jib had been furled. I unfurled the jib, shoved off shore, backed the jib initially to windward to get to this position parallel to the shore. I have just let the windward sheet go, and am preparing to trim both the leeward jib sheet and main sheet, which will commence the boat sailing downwind.
