Chief, Another option for a short Jib Halyard, is to purchase a 60 foot 3/8 inch 3 strand rope, put an eye splice on one end, or tie a bowline, and run the rope through a single sheave on the bow plate. Snap your Jib halyard shackle into the eye splice, and run the halyard to the top, and cleat it off good at the bottom of the mast. As soon as the mast gets at the right pulling angle, you'll be able to pull it up with this line. When the mast is all the way up; bring the line around the mast, above the goose neck fitting,(so it doesn't slide down) and pull the slack out of the line and attach it to your starboard bow cleat. The line will hold the mast, and free you up to get your fore stay connected, and your front Tabernacle pin in place. If you ever get a furler, then you might think about making a gin pole for mast raising/lowering. If you already have a furler, have someone hold and guide the furler as you raise or lower the mast. Regardless of how you do it, remember to keep the wind directly coming from the stern of the boat.Joe
