Raising the Mast
David Cooper
I have a 1975 O'day 25. I usually keep it in the water, however when I have had to take it for painting and routine maintenance I have always struggled a bit trying to put the mast back up. With 3-4 people it goes up quick, but for a trailerable boat I was thinking there has to be an easier way then just muscling it up. If you can help me out I would sure appreciate it. Thanks David Cooper davidcooper@clovisusd.k12.ca.us
Steve Growcock
mast raising system
Rick Leger previously posted an Oday 25 mast raising system in the ODay 25 archives. link below. this may be helpful or give you some ideas. steve!
E
Ed
Another method
Try this link below to a pdf stored on this website. I use this method singlehanded with the boat in the water on a tall rig 25 oday. Your boat should already have all of the parts. You might need some cord to run from the boom end to the triangle plates.
Michael Gordon
Here's an easy system
I bolted together two 2x4's, about 4 1/2 feet long. The bolt went through about 1 foot from the end. I opened up the 2 x4's to create an X (small end up) and put the long ends on the cockpit seats. This created a crutch to hold one end of the mast while the bottom end was attached to the step. Without the crutch, the mast will lay on top of the companionway hatch, and possibly damage it. Note - Tie the crutch to the stern cleats and pulpit so that it is stable. Once the rear pin of the mast step is in place, attach the backstay and sidestays (make sure that they are loose). Next attach the mainsheet block and tackle to the headstay, and use the winch on the mast to pull the mast up. You will need someone at the back of the mast to begin helping it up. due to the severe angle, there is not much leverate at all in the begining. The other methods using a boom off of the front or rear of the mast aid tremendously with respect to the leverage issue, but with a rigid furling foil on the headstay, I cannot see any way to utilize either of those two methods. Michael Gordon michael@chocolatetruffles.com
