Mast raising alone
Bob, When I first got my boat I needed a way to raise my mast alone because I didn't belong to a club at the time and didn't have a mooring. I just wanted to trailer my sailboat to my favorite launching ramp every weekend and when it was time to come home, I wanted my boat to come back with me. The first thing that I needed to do was provide some kind of a mast holder on my stern rail that could be raised to an angle that would allow me to connect the mast Tabernacle pin. A couple of years ago I improved on the mast holder by adding a small roller to it. Now I can roll my mast back into position, instead of lifting it and walking it back. A lot of guys used to take the Jib halyard and connect it to the bow stem plate for the mast lifting process and this is OK provided that you have plenty of halyard. So, my answer to this problem was to get a single sheave block and attach it to the bow stem plate, and take a 60 foot 3/8 inch nylon line with an eye splice on the end, and attach it to my Jib halyard shackle. I raised the Jib halyard to the top and cleated it off at the mast. Now; with all the stays attached except the fore stay of course, which should be bungeed to the mast at reaching distance, I would stand on the cabin with the nylon line in my left hand, and pick up the mast and start bringing it up easy while observing all the stays and turnbuckles for possible kinks or snags. I would get my shoulder into it and when the mast got to an appropriate angle, I would now start pulling on the line. When the mast was up and in position, I needed a way to hold it there temporarily so that I could connect my fore stay. So I took the pulling line and brought it behind the mast and above the Goose neck fitting so that it wouldn't slide down the mast, and attached the line to the Starboard bow cleat after pulling the line up tight. Then I was able to connect my fore stay with a push button "Quick-lock" pin, instead of a regular rigging pin with a cotter pin. I needed a way to put slack in my fore stay to be able to take it off and connect it. So I went to a rigger and he suggested that I install a Johnson Handy-Lock on my fore stay under my regular turnbuckle. With the Handy-lock, I could throw enough slack in the fore stay to connect or disconnect, and never have to touch my other stays. Handy-Locks are expensive and the guy sold me a used one, but it's worked all these years. Now; the most important thing that you have to always remember is the wind direction. When the mast is being raised or half way lowered, the stays are slack and nothing will prevent the mast from going over side ways and breaking your Tabernacle off. So you always want the wind coming from directly behind the stern of the boat when you do any mast raising/lowering. If you're handy with tools, and can build the necessary things that are needed to make your boat easy as well as fast to rig, a lot of this only takes some imagination and minor skills to accomplish. There are other ways of mast raising that involve a Gin Pole and although it may be less strenuous, it's just a little more time consuming than the process that I just described to you. If you decide to look into other ways of mast raising/lowering, check out "The Sailor's sketchbook" by Bruce Bingham. Smooth Sailing!Joe
