Reposition the Gooseneck
I recently had a bimini fitted to our hunter 240. To allow the installer to measure up and fit it I rigged the mast in his yard, securing the boom with the topping lift. I'm only new to sailing and on the two occasions that I had sailed her I had mistakenly sailed with the topping lift attached thinking this was the done thing.
The problem I have now is that the boom now drops roughly 2 inches further than the height of the bimini while supported by the sail only which means we can’t have the bimini erected while under sail.
Having the Bimini lowered is not a preferred option as I have also had 3 sides tailored to fit the bimini which connect to various areas of the boat. Any alterations to the bimini height would throw everything out of whack.
What I am considering doing is having the gooseneck re-riveted 2 - 3 inches higher up the mast. Is there any reason I shouldn't do this or is there a simpler option?
