Recently installed my Windex
I had to lower my mast for the first time to install a Windex. The grainy online photo gave me a theoretical picture of how it should come down and its eventual rise. What I did was;1. Put a rag on the pulpit and rest the mast there. Attach the forward most bolt on the mast plate so it creates a pivot point to swing aft.2. Attach rigging3. Run mainsheet through blocks (depending on length of sheet run as many purchases as you can)4. clip jib sheet to boom stay and run the ends of the sheets through the holes in the triangle plate of rigging and cleat where the winches are. This provides stability on both sides of the boom while raising.5. Begin pulling the mainsheet to bring the boom down, adjusting the jib sheets as necessary to keep the boom centered.6. Once the mast nears its seat, check to make sure all rigging is untangled and base of the mast is ging to line up with the plate, etc.7. Ease it the rest of the way down and cinch the mainsheet to keep the mast down.8. Attach aft bolt on plate and secure the backstay.9. Unclip jib sheets10. Double check fore and back stays, standing and running riggin. I was able to do this with my buddy in about 10 min so there wasnt much time for photos. But having never lowered and raised a mast before, it was suprising simple.Good luck,Gerard
