When I raised the mast with the setup in my album the boat was on the trailer and I used the trailer winch which is rated at 2600#. The winch cranked very easy; almost like it didn't have a load on it. Last fall I lowered the mast while it was in the water using the primary winch (#16- 2 speed) and it went down with out a problem. With the boat in the water I figured it would go up fairly easy this spring but I was in for a surprise. It was much harder than I thought. Much harder. The first 30 degrees of course was the hardest. After that no problem. Next time I'm going to try at least a two part setup between the stemhead and the a-frame. I'm pretty confident this will be sufficient. My apologies to anyone that had problems with my system.
Rich
Rich
